I need a 12volt power source in door.
Bosko5.0
1,067
longwood, FL
I am hooking up a switch in the driver door to operate something, it needs 12 volts and i dont have a volt meter, but that wouldnt help cuz the battery is not in the car. and
1)I need to figure out if there is any source that i could tap into in the door,
2)or should i go outside the door for the power source,
3)it needs power when key on and when engine running,
but it i dont want to drain to much power from something important.
thanks guys:hail2: :SNSign: :nice: Iam in kinda a hurry to finish car.
Your power window feed would probably suffice, right? It's hot with the key-on and with the key in the accessory position.
Good luck.
