I’m looking into buying a crate engine for my 1973 Mustang.
Do you guys know of any good sources to get good prices?
As you will see below I want a motor with a little more power than factory but, I still want it streetable.
The best prices I’ve found was at Doug Herbert High Performance Parts
Have any of you bought one of these motors or know if they are good?
Here are the 2 Engines I’m interested in buying for my Mustang.
(Copy/Paste from dougherbert.com)
408 Ford Windsor Stroker Engine 450+ HP
$4,799.99
Put this Doug Herbert Ford 408 Stroker engine in your early model
Mustang and prepare to leave those Chevy drivers wondering why their hot rods are so slow. This engine produces over 450 Horse-Power and is assembled using the highest quality components for the best possible price.
The engine includes:
• Compression Ratio-10.5-1
• Edlebrock Heads
• Herbert cam of your choice- hydraulic or solid
• Eagle I-Beam Rods
• SRP Pistons by JE
• ARP Bolts
• Plasma Moly RIngs
• Crane Aluminum Rockers
All Herbert engines are balanced, blueprinted and come with:
• Melling High Volume Oil Pump
• Cloyes True Roller Timing Chain
• Clevite Bearings
• Pro Tech Oil Pan
• Professional Products Harmonic Balancer
• Flexplate (call for pricing on flywheel)
521 Ford Big Block 600+HP
$5,995.99
This 521 Ford is an absolute torque monster! This complete engine is perfect for your street, strip or off-road project, and you won't find it at any better price.
This new engine includes:
• SRP Pistons
• Edelbrock Heads
• Clevite Bearings
• Melling Oil Pump
• Crane Roller Rockers
• Fel Pro Gasket Set
• True Roller Timing Chain
• H-Beam Rods
• Steel Crank
• HERCH4B Camshaft
• ARP Bolts
• Professional Products Balancer
• Pro Tech Oil Pan
• Brass Freeze Plugs
Thanks,
Chris
$4,799.99
• Edlebrock Heads
• Eagle I-Beam Rods
• SRP Pistons by JE
• ARP Bolts
• Plasma Moly RIngs
• Clevite Bearings
• Pro Tech Oil Pan
$5,995.99
• SRP Pistons
• Edelbrock Heads
• Clevite Bearings
• Melling Oil Pump
• H-Beam Rods
• Steel Crank
• HERCH4B Camshaft
• ARP Bolts
• Pro Tech Oil Pan
Thanks,
Chris
