I need help spending my money
tistan2
128
I have to order new push rods and new lifters for my car. I have to spend $500 with summit to get 0% for a year. I figure the lifters and pushrods will run my about $200 so I have to spend at least 300 more. I am thinking either a steel or aluminum flywheel, or a mds 6al ignition. With my mods which do you think would benifit me the most.
bbk cold air
pro-m 75 mm mas air
ford motorsport 65mm throttle body
cobra intake
ford 24# injectors
afr 165s
scorpion 1.6 rockers
aeromotive fuel pressure regulator
190 lph fuel pump
b303 camshaft
msd billet distributor
underdrive pulleys
mac headers
mac xpipe
mac catback
king cobra clutch
mclead adjustable clutch qaudrant and fire wall adjuster
pro 5.0 shifter
ford motorsport aluminum driveshaft
ford motorsport 3.73 gearset
eaton limited slip differential
moser 31 spline axles
Kyb shock and struts
steeda caster camber plates
You've already got a laundry list of stuff on your car man, lol. Maybe you could get a set of slicks if you don't already have some. I kinda like the Crane HI-6 Ignition and the LX92/1 coil (it's on my "to buy" list). This wouldn't be spending much but if you have the hood clearance you could get a phenolic spacer for your intake. Need some gauges? Have you relocated your battery to the rear?
I'll post back if I think of anything else! :D
oh i thought you were sending out checks. you could get me some gauges. i do not see a aluminum raditator or elctric fan in your sig. also i see alot of engine, but no springs or control arms. would probably be a big help.
That is a good one. I did not even think about that. I will definitly get one of those. I don't want to get slicks because I have yet to put subframe connectors on. I am going to order my suspesion from either maximum motorsports or saleen and both of those come with the connectors.
I have an electric fan and my car doen not have any cooling issues with the stock radiator.
Hello! I would at this point in your build put it on the bottle.Maybe one of them new gadgits to give 0-60 and 1/4 mile times and speed.Maybe work on the sound system.I have a cyberdyne digital dash from there and love it.So so easy to install and it gives 0-60 and top speed.Its nice to play with and looks cool as hell.LOL Later Sub
what is the difference between the crane hi-6s ingnition and the hi 6 with the lx-92 coil. I am looking in summit magazine now and the hi6s specifies for use with a 86-95 mustang.
I don't think you will beniefit from a aftermarket ignition.The tfi system on fords is a strong ignition with just adding a crane ps-91 coil.Now if you opt for a high hp nitrous you would beniefit from it.Do you have drivability problems or fouled plugs?That is the only reason I see for needing it.
