- Dec 30, 2004
- 60
- 0
- 0
Alright i pulled my motor to change to oil pan gasket, RMS, and some other stuff, today i got everything back together and it wont start. It will fire then die out, checked fuel pressure and spark both fine. also checked the firing order thats right to. but i did notice that i had the two plugs that go to the throttle body unpluged the first couple times i tried to start it. could that be the problem?? do i need to disconnect the battery to let the computer "re-learn" with those two plug connected?. Oh also when i was pulling the motor i ripped the end off the chassis ground that goes to the motor mount, but i replaced it with a 4G ground wire. any help would really be apprecatied
