I need to see your rear end.
I know a lot clicked in here just to see what's going on. I meant, if I can have a pic of the rear of your car. Why? I want to see how low your sway bar is. I just got one and mine seems to be pretty low. A ground shot would be perfect. I already tried installing it the other way, but it won't fit.
Thanks
These are just a couple i had laying around. Crappy, but thats all I've got. It should be tucked-up so high you never usually see it. Hopefully this gives you an idea. Unless you got the wrong one, it should only bolt-in one way. Mine's an FMS one, if that matters.
Edit: Damn, I think I'll be hitting my gas tank with some black paint in the spring time.
I don't currently have pics but my sway bar hangs noticably lower after installing the MM LCAs. I've scraped it once on my Moms neighor's driveway. It definitely sits lower than before and it's the stock bar. Do you have aftermarket LCAs. If so that can be the reason it sits lower.
