  • 1994 - 1995 Specific Tech
i REALLY Really Need Help!
  • Thread starter Thread starter OrangeMustangGt
  • Start date Start date Dec 16, 2005
First Prev 2 of 2
blk9450
1,507
your moms bed
Dec 18, 2005
#21
  • Dec 18, 2005
  • #21
yea autozone trys to sell you the fox pip and will argue with you and tell you its correct. some other fords had the same pip, i dont know which ones though. anyway did you check your coolant temp sensor? may sound weird but i heard that has something to do with only starting at wot ...
HISSIN50
34
129
Dec 18, 2005
#22
  • Dec 18, 2005
  • #22
As you know, cranking the car with the throttle at WOT kills the injector pulse. Are you fouling plugs?
If it is an issue related to your nice Turbo set-up, that is gonna go beyond me.
Good luck.
OrangeMustangGt
1,976
Cape Cod, MA
Dec 18, 2005
#23
  • Dec 18, 2005
  • #23
first of all, hissin, i cant thank you enough for all the help.
No, it has nothing to do with the turbo setup, as it was running great after i got my dyno tune chip, and it just started acting up.It hasent fouled any plugs, but it just dies and wont run for crap out of nowhere.....and its definatly getting plenty of fuel, its belching out rich-burn ur eyes smoke as it runs. Honestly, im at a brick wall with what i should replace/test next. So, the car stis in the garage still...
BlackVert
5,589
9
98
Bethesda, MD
Dec 18, 2005
#24
  • Dec 18, 2005
  • #24
GreenMustangGt said:
Do ECU's generally go bad? When i remove the chip, i really dont get any ecu codes.
Please help?!
there is a memory location that the ecu checks to see if the rom is "ok" or not. without a chip, that memory location is supposed to have the value 8192. in the tweecer, it is called the "checksum base address".
anyway, chips are supposed to set that location to 0, which disables the checksum checking or maybe it tells the computer that it is a custom calibration, something like that. i wonder if maybe your chip doesn't have that location cleared, which is why it spits out that code.
94-302-vert
1,947
NE CT
Dec 19, 2005
#25
  • Dec 19, 2005
  • #25
MAF.
I didn't have mine connected when I first got and started working on my car and in order to get it running I had to keep pumping the gas to keep it running.
Just a thought.
BlackVert
5,589
9
98
Bethesda, MD
Dec 19, 2005
#26
  • Dec 19, 2005
  • #26
HISSIN50 said:
... a PIP can be bad at any time. It generally does get funky when hot, but it is not as heat-related as a TFI. Sometimes a hot PIP will allow the car to start back up and sometimes even after it has cooled, it still wont start. TFI's often come back to life once they cool down. TFI's can also allow a high-speed misfire as they are on the outs ....
yeah, i was incorrectly lumping the pip in with the tfi.
mo_dingo said:
... Get a noid light ...
just curious, what is a 'noid light'?
OrangeMustangGt
1,976
Cape Cod, MA
Dec 19, 2005
#27
  • Dec 19, 2005
  • #27
Today i took apart, cleaned, verified, anit-ox'd every single connector in the engine bay. No help.
I checked the timing, spout out, 10adv....perfect.......No fuel is coming from the FPR vac line.......
As the last thing i tried, i war barely able to get it running.....and with it belching eyeburning smoke, i put a scantool on it, and went into monitor mode, and i saw when i plugged in the MAF, it went from 0 volts to 5.....because it wouldent start with the MAF plugged in.
So, im thinkin this may be the problem....how can i check a maf? Its a Mass Air systems Blow through, and it wasen't cheap.....maby they can help me>?
blk9450
1,507
your moms bed
Dec 19, 2005
#28
  • Dec 19, 2005
  • #28
sounds like the sensor is bad. read this
http://forums.stangnet.com/showthread.php?t=569615&highlight=maf+signal
4Jenna
4,326
AZ
Dec 20, 2005
#29
  • Dec 20, 2005
  • #29
C'Mon we all know that its only a myth that turbomustangs actually run..haha
Goodluck man!
OrangeMustangGt
1,976
Cape Cod, MA
Dec 20, 2005
#30
  • Dec 20, 2005
  • #30
COMON NOW, it was runnin great for about a month lol, anyhow, i DID pull the top off the electronics in the MAF, and found what looks like a burnt component....soo i think its found....from now on, i wont be leaving it out in the water
BlackVert
5,589
9
98
Bethesda, MD
Dec 20, 2005
#31
  • Dec 20, 2005
  • #31
i'd claim the cookie (post #7), but i think blk9450 gets it for post #3 ...
fawcett
380
Cohasset, Ma
Dec 21, 2005
#32
  • Dec 21, 2005
  • #32
i read almost every post you put out green, your lack of fear for tearing into your stang amazes me. i am gaining the courage needed to tackle my next projects thanks to you and a lot of other guys on stangnet.
so this is a real (stupid?) suggestion: have you tried clearing codes? i dont think i read anything saying that you disconnected the battery and let the computer forget everything. maybe if you try that w/ and w/o your chip, with the spout on/off, whatever.... i see you think your MAF is shot, i thought that was one of my electronic gremlins keeping my stang off the road for the whole summer. it was something inside my dizzy, i ended up replacing everything ignition related (all mallory hi-fire vi) until i got to my dizzy. once that was replaced the stang woke up and terrorizes the streets of new england. i have the saleen heat extractor hood so i think that water got into my dizzy during a storm, the vents let water go right through.
good luck man, i want to meet up with you some time im not too far away from the cape (hingham, ma). i want a ride in that tt stang, im just afraid that if i get a taste i may have to follow your lead and tt my stang as well
-fawcett
First Prev 2 of 2
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
