I replaced the clutch, now 2 things don't work..
Timin
207
Houston
The first thing I noticed that did not work when I got in the car to test it out is the Speedo. The tach works just fine but the speedo doesn't work at all. Second, both Cigarrete lighters don't work either. I pulled the codes and the Speedo actually showed up. I have a Dallas Mustang Speedcal on the car, and I am almost certain I put everything back the same way. I've been messing around with car and I can't seem to figure out why these to things don't work. I checked all fuses under the hood and inside and they seem to be working fine. Anyone know of a wire I may have tripped/shorted out while working on a clutch, or any other ideas?
**Update**
Problem has been fixed, had an accessory fuse blow under the hood.
