I suggest everyone with the T-45 reads this
Smokin35s
85
So, if you remember I broke my T-45 in my 99 Cobra. To see what is wrong do a search in the SVT forums. Well I took it out and it sucked bad (top starter bolt and top passenger side bellhousing bolt) but I got it out. To bring it to a shop it would be around $500-$600 to fix it and my other option would be to go pick one up from a fellow stangnet member in Chicago for $300 which was a great deal. However being a broke azz college student those options were hard to reach. So I decided to crack it open and see if I could do anything in my garage. When I took off my back cover there was a broken piece on the magnet but I couldnt see where it came from. Then I took off the front cover and sure enough the little shift plate that moves the 3/4 shift fork on the shifter rail was broken. So after looking it over for a long time I figured the only way to get it off would be to take off all the gears pull that rail out and get that piece and I didnt want that headache, so I brought it to the shop. The shop told me that the piece was $150 and the labor was $400 even after I took a lot of it apart :bs: . I didnt believe it so I went to Ford and the part was only $7 so I ordered one and brought the tranny to my garage again. After looking it over some more I found the roll pin that holds all the pieces together on the rail, so i shifted it around and eventually got the pin pointed up, drilled a nice size hole in the case, punched the pin out, took out the broken piece, put in the new shift plate, tapped the hole, got a new drain plug like the one on the side of the tranny, put it in and now it works great!!! All for $7 bucks!!! I dont know if ya got all that but I can answer any questions. Also if anyone takes out that tranny cut off the two ears on the bell housing top, it makes life a lot easier.
Just a heads up,
Justin
wow great work. sounds almost too good. What was your tranny doing before you fixed it? the symptoms I mean. I just hope and pray my t45 will hold for the 3rd time for me, so that way I can just get a tko500 a few years from now :D when maybe Ill have the money...
hey, i messed up my t45 and have no idea wha the hell i did! I only have 1st gear, it wont go into any others! Also it stays in gear...when i put it in neutral and take my foot off the clutch it is still in gear. I think it is a shift fork but i dont know
Poonstang that was almost the same problem I had, however i had a clutch still. Take it out any questions message me I have a few other shortcuts to do too.
Thanks, Justin
P.S. 1000 hard miles on it already and running strong!!!!!
