I6 front suspension
  • Thread starter Thread starter BarnStang
  • Start date Start date Feb 20, 2006
BarnStang
1,260
Hagerstown, MD
Feb 20, 2006
  • Feb 20, 2006
I have been told that the I6 center link, inner and outer tie rods need to be replaced with V8 parts cause they are too weak to support a 289? Seems like a streatch to me. THe car has factory power steering too. DO I really need to change out all that stuff? Seems like there is not a tremendous amount of weight diff btwn the I6 and the 289.
red65
411
Ann Arbor, MI
Feb 21, 2006
  • Feb 21, 2006
You certainly are going to want to swap the front spindles from the I-6, and upgrade to 5-lug brakes, hubs and wheels. The main reasons to do that include the brake sizing (the 9" 6-cyl brakes were on the hairy edge of adequate even for the 6-cyl car), and the strength of the spindle (V-8 spindles are visibly more robust). In doing that, I believe you'll find that the 6-cyl steering linkage no longer fits the V-8 spindles - different tapered bore in the steering arm, so you'll end up swapping it anyway. Of course, lots of people get away with mild V-8 swaps into 6-cylinder cars and do none of this - it's all about your risk tolerance, I suppose. I'd strongly recommend going the whole nine yards.
dennis112
1,561
36
79
Amish Wonderland of Central PA.
Feb 21, 2006
  • Feb 21, 2006
Very good reply. All I can add is that the 6-cyl 9" brakes are very inadequate for a good running, heavier V8 car.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Feb 21, 2006
  • Feb 21, 2006
doing the engine swap isn't the problem, the problem is when you exspect it to handle and stop like a v8 car. If your doing the swap because yur 6 is junk and needs upgrading then go ahead and do it, just baby it until you upgrade the front and rear ends.
BarnStang
1,260
Hagerstown, MD
Feb 21, 2006
  • Feb 21, 2006
I have the 5 lug spindle withe the drum and brakes and all attached. So I understand that I will need the outer tie rods to fit the spindle. Will I really need the inner tie rods and the center link? I have also read that there are problems matching up a V* centerlink bar in an I6 car with P/S...
Thanks!
BarnStang
1,260
Hagerstown, MD
Feb 21, 2006
  • Feb 21, 2006
Oh, and I have a 5 lug rear that also came with the car...
red65
411
Ann Arbor, MI
Feb 21, 2006
  • Feb 21, 2006
As far as I know, you're in uncharted territory trying to match a 6-cyl center link and inner tie rod ends to V-8 outer tie rod ends. I don't know the answer, but the conversion's been done often enough that someone may have tried it.
A new V-8 center link and inner tie rod ends really aren't very expensive (relative to the overall price tag I'm sure you're accumulating), even if you have to buy a rebuilt V-8 steering cylinder to go along with them... Most people just swap the whole assembly (I did, but I have manual steering, so I don't know the answer to your PS question).
DukeGnarley
597
Auburn/Ellensburg, Wa
Feb 21, 2006
  • Feb 21, 2006
I did the v-8 swap in my '66 and did everything except the steering linkage, seems to work fine.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Wheels-Tires Front end shimmy on 79 foxbody
  • 79fox2245
  • Jul 4, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
General karthief
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
J
Severe shaking/vibrations in steering wheel
  • jacket999
  • May 20, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 1, 2025
NtheGAME
N
G
Suspension
  • Gpayan04GT
  • Apr 28, 2024
1996 - 2004 SN95 Mustang -General/Talk- Apr 30, 2024
Mustang5L5
