IAC? god this is frustrating
95GTV8
386
Washington State
I just had my starter motor replaced. Car starts fine/drives fine. Now when I put the car in neutral about 65% of the time it dies. I thought it was the IAC so i cleaned it out with carb cleaner and that seemed to work for a day. I turned the car on after doing that let it idle for like 2 minutes and it idled and drove him beatifully. That was yesterday, today i go for a drive uptown and it dies prolly 65% of the time it's in neutral. Is this the IAC?
Did you set your no load hot idle where it requires IAC input (a duty cycle %)? If so, and the IAC simply crapped out, that could be an issue. I've had good luck setting my '94's hot, no-load idle with no IAC duty cycle.
Pulling the codes would be step one.
Good luck.
Simply stated, you'd get the engine hot. Then disconnect the IAC and set the idle where you want it. Then reconnect the IAC and see how it does.
Having the IAC disconnected during the setting of the idle-stop screw (I dont hose with the bleed screw) mimics zero IAC duty cycle.
Good luck.
95GTV8 said:
Allright thank you. Is it possible for the car to drive w/o the IAC? I'll try this tomorrow.
When I have a hot, no load idle situation I can. The car would not start (the IAC is part of the cold idle enrichment process), allow me to run AC (IAC increases the idle a couple hundred RPM for that), etc.
I've known of a couple guys in warm climates who adjusted their idle up and then ran with no IAC or a block off plate for the summer.
In case it helps is this article. Good luck.
Shaker, technically yes. I'm not real big on the mandatory "You need to clear the KAM" statements that are common. I often dont disco' the battery.
So long as the stored values werent so far out of whack that the car will run ok after the cleaning (it hadn't need to radically adapt), I just let it relearn on its own from the old setting. It doesnt hurt to reset the KAM though.
Good luck.
