- Dec 6, 2004
- 1,865
- 24
- 58
Im getting the feeling its time to do some general matenince on the Stang.
I have an idle issue sometimes. If I come to a stop about 1/5th of the times the idle will bounce up and down between 400rpm, and about 7-800 where it should idle at. I assume this is just a dirty IAC since everyone complains about it, and that usually is the fix. What do I clean it with, and is there any technique to it?
And plugs... Dont know when they've been changed last, and I have a slight bog when the car is first cold started. Usually just through first letting the clutch out, or first and a little bit of 2nd gear. What are the best plugs to use? Someone I know told me to get a certain kind, but I want to know what you guys reccomend also.
Last... fuel filter. I imagine this could play into the miss after first starting up also. Again, dont know when it was changed so I might as well do it also. Any particular brand or anything thats best?
