IAC question
I was just wondering...
When i start my car I usually have to crank it twice to get it to run and is usually followed by rough idle until you drive it for a little . One of the things I'm looking at is the IAC. So I disconnected the IAC while it was running...should it act different? Also, I know on most cars when you turn on the A/C, the idle changes to compensate, does the idle change on these cars?
On the same fuel note, you can try cycling the key a few times before ever cranking the engine over (to build fuel pressure). If you do this and then it starts immediately, that suggests a pressure issue.
The IAC will compensate your cold idle, and loaded idle (like when the AC is on, as you noted). The hot (non-loaded) idle might not be affected, depending upon how your mechanical idle is set.
Good luck.
I cycled the key a couple a times, like you said. Turned the key over...started up, but immediatly started losing idle speed, luggin' and crap, till its just on the verge of dying then picks itself up (w/o me touching the throttle) and idles fine. what do ya think?
The check engine light has never come on. Im gonna hook a scanner up to it to see if its throwing any codes, also Ill probably try that fuel pressure tester.
Codes and FP testing definitely are next steps. It can still be an IAC issue but because it's tough to test an IAC on your own (it has a square wave output), you kind of replace one after deductive observations.
Good luck.
