IAC? TFI module?
  • Thread starter Thread starter n2o abusn coupe
  • Start date Start date Mar 12, 2004
N
n2o abusn coupe
12
  • Mar 12, 2004
well my 88 5.0 is acting weird.
during normal driving i have no problems with idle, but if i go WOT for any amount of time, and then idle.. it idles at about 2k or more....
if i turn off the car and restart it, it is normal again...
there are no vacuum leaks that i know of at the moment.
A
autoXr1
1,838
Michigan
Mar 13, 2004
  • Mar 13, 2004
You appear to be on the right track. Most likely the IAC. I think it may be time to clean out the upper intake system. Most of these little idle problems occur when hoses and air passages get all "gunked up" with that oily, dirty sludge from the EGR and PCV system.
Spend a weekend sometime and pull the upper intake, throttle body, IAC, PCV, vacuum hoses, etc. off. Then get 3-4 cans of throttle body cleaner and some bottle brushes and have at it. I think you'd be amazed at how much is in there. BTW, depending upon how old those gaskets are, you should have new ones ready to go on. Sometimes, they get damaged during disassembly. It also gives you an opportunity to check for cracked/dry rotted hoses that may need replacing.
TFI modules tend to exhibit their symptoms in various types of misses and ignition advance issues.
Just me...
J
Jesseswhite87GT
118
Springfield, MA
Mar 13, 2004
  • Mar 13, 2004
I had idle problems and bought a new IAC and the problem was still there. I disconnected the IAC and the car runs awesome. It idles at about 900 RPM's.
Dardy
89
Delaware
Mar 13, 2004
  • Mar 13, 2004
I had the exact problem with my 93 and I fixed it by cleaning out the IAC and Setting the TPS
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
4K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
