iac valve
  • Thread starter Thread starter smitty1991
  • Start date Start date Mar 27, 2009
smitty1991
89
iowa
Mar 27, 2009
  • Mar 27, 2009
i have a 1992 lx 5.0 with 59,000 original miles, its in exelent condition. it has been idling a little rough and it whistles. i was told that it may be the idle control valve. it was idling around 500rpm or so. the car has bolt ons but no heads, cams, etc just exhaust etc. any help would be appriciated thanks.
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Mar 27, 2009
  • Mar 27, 2009
Simply start by removing it, and cleaning it out with carb cleaner.
I'd also check the tps voltage.
HISSIN50
34
129
Mar 27, 2009
  • Mar 27, 2009
I dont like to clean IAC's unless I'm willing to replace them. The harshest solvent I'll use on them is WD-40.
Is the whistling coming from the IAC itself?
Are there any vac lines that are cracked or loose?
Did you pull codes yet?
smitty1991
89
iowa
Mar 28, 2009
  • Mar 28, 2009
it only whistles when im driving, its really noticable around 35 or 40 mph.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 30, 2009
  • Mar 30, 2009
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Mar 30, 2009
  • Mar 30, 2009
An IAC valve will only whistle at idle. Did you install an aftermarket throttle body? Sometimes they will whistle under part throttle.
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
