IAC Valve
Junkyard...I've got a few usually they're just full of gunk. Cleaned one out yesterday and when i poured the carb cleaner out it looked like coffee
get one of the newer style that have the adjustment needle. then you can adjust the idle air screw without having to reset your TPS
most of the fords after I think 94 had them.I pulled one off a 3.8 tbird a few weeks ago. theres a black cap sticking off the side of it. cant miss it.
You don't have to modify the wiring harness to use it do you? By that I mean do they have the same connector? My start up idles Been really bad and I was about to swap IACs (AGAIN!!)
