  • SN95 4.6L Mustang Tech
IAT Sensor Relocation
  • Thread starter Thread starter Roblu98
  • Start date Start date May 10, 2008
R
Roblu98
94
East Fallowfield, PA
May 10, 2008
  • May 10, 2008
I have a friend that needs help. What wires do you use in the MAF harness if you are relocating your IAT sensor? He used the two out side wires but he is getting CEL. Dose polarity matter? The car is a 2003 GT. Thanks for the help!
D
darkside03gt
851
Sacramento CA
May 11, 2008
  • May 11, 2008
I dont think polarity matters but he could try swaping them around.
are you sure he cut the correct wires?
R
Roblu98
94
May 11, 2008
  • May 11, 2008
I dont know he said that he cut the two outter wires of the MAF harness. Dose any one know what wires should be used?
BennyBlown2v
1,233
Carmel, INdiana
May 11, 2008
  • May 11, 2008
Wires one and six, the wires on the outside edges. And if I remember correctly, polarity does matter...however I don't remember which direction is which hah.
CTGrey02
1,403
Bristol, CT
May 12, 2008
  • May 12, 2008
Swap em if your still getting a CEL. He mounted it AFTER the blower correct? In the discharge? You sure the connections are good?
SilverBullet00
1,150
Wichita, KS
May 12, 2008
  • May 12, 2008
I thought polarity doesnt matter?
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
May 12, 2008
  • May 12, 2008
shouldn't have to cut any wires at all... mine just removed the gray and redish wire (I think) and the clipped right on the IAT, sealed with silicone.
R
Roblu98
94
May 13, 2008
  • May 13, 2008
We fix the problem. The polarity dose not matter. We did mount it after the superchager. The CEL turned out to be when he reconected the discharge tube it popped back out of the rubber sleave. It was venting metered air into the air, causing the motor to run really rich causing CEL on the O2 sensors. What a jack ass! Thanks for all the help!
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
