I found what looks like some kind of tag on the ear where the starter goes and it says 4A20 or 4A28?
You sure about that?. Ford used the C8 (1968) rods through 2001 in the 5.0L.![]()
Daniel
I've run across at least three 90's 5.0's that had a new rod: F1TE. And although it's a newer forging, it ain't a better one. Out of those three, two had broken rods. (rods not bolts)You sure about that?I've run across at least three 90's 5.0's that had a new rod: F1TE. And although it's a newer forging, it ain't a better one. Out of those three, two had broken rods. (rods not bolts)
Are you guys sure the Tbird came with an HO???
It is definately a Tbird engine, or at least Tbird EFI setup.
Anyway, you should check the firing order.
Cars and trucks with roller 5.0s, non-HO, used the standard 302 FO.
The HO engines are the only ones that got the Windsor FO.
This may have changed for the Exploders with GT40 stuff, but for the others that is the way.
I have a non-HO roller in my truck...
Dave
Just for kicks, how do you plan on getting that comp ratio? Not saying you can't, on the contrary, it's possible, but most people assume that all that's needed are flat topped pistons. But it takes the right ones.this kit maybe, if if i don't stroke it, my heads have been milled 20 thousandths so they are around 58cc not 60cc. Do you reccomend another kit?
http://store.summitracing.com/partd...889096+4294870280+4294891093+115&autoview=sku
I may decide to stroke it but that is still up in the air. I need to get the block to the machine shop to see what kind of bore it needs. If it needs to got to .030 overbore i will probably get a stroker kit.
