Identifying E7 cylinder heads.
  • Thread starter Thread starter FrumRoll
  • Start date Start date Apr 11, 2006
F
FrumRoll
38
  • Apr 11, 2006
I was doing a plug change on my car, and I ran into a little problem. The plugs NGK recommends for an '87GT are UR45's. The plugs I pulled out are Autolite 103's. The 103's have about half an inch longer threading. Now I need to figure out if someone installed the wrong plugs before I got the car, or if the car has had a head change. Although it still has the stock intake and who swaps heads and keeps the stock intake? I did check to see if the heads were magnetic and they are so at the very least they appear to be iron, I'm hoping someone can help me identify the heads without having to take off the intake or valve cover.
F
FrumRoll
38
  • Apr 11, 2006
Sorry for the double post, but I have some more info.
I found a picture, I have the same plug angle as the GT's. Where these two heads say "GTP" and "GT" my heads say "11" or "II".
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Apr 11, 2006
  • Apr 11, 2006
You have E7's by the sounds of it. Probly just a missprint in the NGK book or the parts store was wrong.
troyGT03
278
too close to memphis,tn
Apr 11, 2006
  • Apr 11, 2006
find a casting #. it will say E7TE if you have stock heads. it wont be where you are seeing the GT or GTP casting on those heads.
F
FrumRoll
38
  • Apr 12, 2006
Do you thing NGK was wrong, or whoever had the car before me installed the wrong plugs? I also believe I have E7's and went ahead and installed the UR45's. I looked on autolite's webpage and the plug they recommend is not the 103. I believe it was 2445 or something similar, anyways it cross-referenced to UR45 so I went ahead and installed them without issue.
Z
ZephyrMotorspor
88
Tampa, Fl
Apr 12, 2006
  • Apr 12, 2006
where would the E7TE be cast on the head? would it be visible w/o having to take the upper manifold or valve covers off?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Apr 12, 2006
  • Apr 12, 2006
Just take a valve cover off... that's what I did when I bought my car- you'll always know then
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
Engine HCI Upgrade
  • foxbodyclark
  • Jan 21, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
Mustang5L5
