Identifying E7 cylinder heads.
FrumRoll
38
I was doing a plug change on my car, and I ran into a little problem. The plugs NGK recommends for an '87GT are UR45's. The plugs I pulled out are Autolite 103's. The 103's have about half an inch longer threading. Now I need to figure out if someone installed the wrong plugs before I got the car, or if the car has had a head change. Although it still has the stock intake and who swaps heads and keeps the stock intake? I did check to see if the heads were magnetic and they are so at the very least they appear to be iron, I'm hoping someone can help me identify the heads without having to take off the intake or valve cover.
Sorry for the double post, but I have some more info.
I found a picture, I have the same plug angle as the GT's. Where these two heads say "GTP" and "GT" my heads say "11" or "II".
Roland69 said:
You have E7's by the sounds of it. Probly just a missprint in the NGK book or the parts store was wrong.
Do you thing NGK was wrong, or whoever had the car before me installed the wrong plugs? I also believe I have E7's and went ahead and installed the UR45's. I looked on autolite's webpage and the plug they recommend is not the 103. I believe it was 2445 or something similar, anyways it cross-referenced to UR45 so I went ahead and installed them without issue.
