Identifying heads
subcreep
30
Jax, FL
I just bought a '92 hatchback that hauls..... It has an aftermarket mass air sensor and throttlebody, gt-40 intake, cold air induction and an unknown crane cam. This car isjust plain fast, but I can't see how it could be this fast with stock heads. How can I identify what type of heads I have? The valve covers are stock 5.0 if it's any help.
The casting numbers are casted into the heads.. The bad news is you can only see them if you remove the lower intake and use a mirror to locate them.
If you happen to have gt40 heads they will have the gt40 casted into the front lower corner of the heads,
Dont discount stock headed cars as slow. There are several stock headed stangs in the 12's NA. They could be ported stock heads also.
GT40 iron heads have three vertical lines cast on the ends of each head. You can see them if you are looking from the front of the engine bay. I think they have GT stamped on them somewhere as well.
