Identifying What Year Your Fox Body Is?
black beard
Active User
Mar 11, 2017
21
Im looking to buy parts for my coup lx and previous owner says its a 1983 with 1987 fox body outside shell. The door is from a 91 so the sticker doesn't help me. Is there any other features the 1983 model has that will tell me he is right? one of the reasons i would like to know is because im changing the engine mounts from ridged to polly and i cant find any for a 1983.
I really couldn't answer that. I have experience with 1985 and 1993 Mustangs. According to a book I have, the 5.0 motor mounts are the same for 83 on up until Ford used convertible mounts on all Mustang 5.0L cars.
The book mentioned is The Official Ford Mustang 5.0 Technical Reference & Performance Handbook. Covers cars from 1979 through 1993.
What year does your title say the car is?
The VIN on the dash isn't part of the dash, it's riveted to the body. There's a cutout so you can read it through the windshield. If the VIN decodes as an '83, then that is what year the car is.
Either way, the motor mounts for '84 and up cars should work. Your engine might sit a bit higher too.
The 1984 5.0L engine was a direct carry over from 1983. No external changes were made.
The 1984 5.0L engine was a direct carry over from 1983. No external changes were made.[/QUOTE
it says 1983, learning more every day , thanks for the response
Ford stamped the VIN all over these cars.
The one on the dash is welded to the frame of the vehicle. This should match your title. Go by this one.
There are 11 other locations that the VIN was stamped on around the car as well, most body panels will have this. Also, the motor, and trans will also have a partial VIN stamped on them.
VIN on the "dash" (actually the firewall) is not welded in place. That VIN plate is riveted to a metal tab that is part of the firewall.
There are only two places that the VIN is stamped on the body. Beneath each outer fender is plate that is spot-welded to the inner fender. On that plate is stamped the whole VIN (through 1980) or the last eight of the VIN (1981+).
Stickers with the complete VIN, that were placed on all major fixed or removable body panels, didn't start until the 1987 model year.
The full (-1980) or partial (1981+) VIN is also on buck tag, in addition to being on the engine and transmission.
