stangedout916 said:i dont know but i was wondering where this is on a fox and how hard is it to replace? if you know let me know. thanks
chris
They are the same thing, just look different. I'm pretty sure the housing (where it mounts to the TB) is the same, but am not positive.bcd said:is there any difference between the IAC valve in a fox and the one in an sn95?
They do. I am using a Fox computer and wiring harness in my '65, but the engine started out as a SN95, so it still has the SN95 IAC, TPS, and TB. It works perfect.bcd said:they bolt up the same and they plug in the same but i am wondering if they take the same voltage. the ford place calls for two different part numbers
i appreciate it man. i am in the same boat cuz i put a sn95 motor into my coupe. i know your asking what kind of an idiot would do that. the answer is this kindSpeed_Demon1965 said:They do. I am using a Fox computer and wiring harness in my '65, but the engine started out as a SN95, so it still has the SN95 IAC, TPS, and TB. It works perfect.
It takes all of 2 minutes to change!!
