I am having problems getting my 89 to idle properly. Also after the vehicle gets to temp it begins to have a check engine light and will stumble, backfire and miss. These problem started from nowhere and im lost where to go next. I replaced the idle IAC, coolant temp sensor, and complete msd ignition, new calibrated BBK MAF and nothing yet. I try to ajust the idle screw and i have reset the ECU multiple times with no success. I dont know if it matters but I have an x303 cam, trick flow track heat intake manifold, BBK cold air intake, throttle body, egr plate and MAF, MSD ignition with a 6AL control box, hooker super comp headers, h-pipe, and flowmasters. I would appreciate any help i have such much time and money in this project and i still cant get it to run correctly. I tried setting the TPS as well does anyone think a bad TPS could cause all those problems. Also I am not running the smog pump so that sensor is obviouslt disconnected.
