idle fluctuating constantly
  • Thread starter Thread starter LS what
  • Start date Start date Sep 8, 2005
L
LS what
  • Sep 8, 2005
hi i have a problem with my idle, i tried searching but couldnt find someone with this exact problem. When i am driving and let off the gas the idle will drop really low, sound like its about to die, then rev back up and back down again and so on. Finally after fluctuating for a little bit it returns to normal. It is really bad when i let off the gas and make a sharp turn, it drops really low and sometimes even dies. Has anyone had this problem? thanks for any help
P
Polter83
74
  • Sep 8, 2005
Did you pull the codes?
Try this.. have it at idle... take a can of carb cleaner and spray around the intake and inner valve covers and throttle body. See if the rpms increase. If so, you have a vacuum leak. Cheap test, report back.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 10, 2005
  • Sep 10, 2005
Read through the Sticky at the top of the forum " Help me create the urging Idle Checklist" and you will find the answer to your idle problems.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
W
1993 LX 5.0 dies after ignition parts replacement
  • Warhorse85
  • Aug 16, 2025
  • 5 6 7
5K
Fox 5.0 Mustang Tech Nov 4, 2025
General karthief
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
