I was swapping around intake tubes/MAFs today to test out some things. When all was done I ended up with the same MAF (but different IAT) and the car drives about the same except the idle hangs up to 2100 or so if you put in the clutch when you're driving, once you get below 10 MPH or so the idle comes back down to normal
. You can feel it when your driving as well as the car seems to want to cruise on its own. Obviously the IAC is suspect but it was working fine before the intake tube stuff and it comes back down once you get close to a stop
. Idea's?
. Idea's?
