evening fellas,
I just joined up the other day and wow there is wealth of great information here.
So, I'm here looking for some guidance on my 91' 2.3. She has been in the family since we got her new from the dealer some time ago and has since then completed 221K with us. Now I know she has been leaking some oil from the area near the oil plug, I have never really paid too much mind to that aside from adding a dash or a dab here and there but the other day she started to act kind of funny. the check engine light lit up and for about 30-40 mins anytime i came to a light or got held up in traffic she started to idle around 500 but after that period of time everything went back to normal. about two days later at a light she idled funny again but this time died and took almost 4 cranks to get her up and running. Only to fail again a 1/4m down the road. I popped the hood and nothing smelled funny, I then proceeded to remove the air intake pipe where i found a bunch of oil in the tube and some in the throttle body. Also i noticed the breather inlet rubber hose that connects to the throttle body was completely loose/worn and was leaking a bit. upon examining the valve cover/head seam i noticed some dried oil and coolant stains. I cleaned what i could, closed her up and got her home. i took the air bypass valve out and cleaned it up, the piston seemed to move without a prob. i fired her back up but this time the highest she would idle was 500 with the bypass valve plugged in and the idle adjustment screw all the way in. i started to do a compression test and only got to do the passenger side the one closest to the front of the car was @ a 150 and the one closest to the firewall was about 110ish the others were closer to the 140 mark. i tried to do the other side but only got as far as shifting the alt so i can get to the plug before the rain started. Now i plan on replacing the valve cover gasket as well as the intakes, replace breather inlet hose, change spark plugs (which look find ) and spark wire plugs.
Should I be looking out for something else? any suggestions
