idle problem when engine warms up
  • Thread starter Thread starter fox182
  • Start date Start date Sep 19, 2010
F
fox182
17
  • Sep 19, 2010
i have a 92 coupe that idles fine on a cold start for about 20 minutes until it completely warms up then all the sudden the idle falls slightly from 900 to around 600 and the idle sounds kinda weak, if i turn the ignition off and start it back up it idles normally again until a few minutes and it does it again, and also while driving when i push the clutch down to make a stop, the engine will almost stall then pics back u to idle, other than than it seems to run ok, its a 5speed with afr165s, trickflow trankheat intake and a comp cam, the fuel injectors are still 19lbs i gotta save more money for them,, not sure if that could be the problem,anyone have any ideas?
HISSIN50
34
129
Sep 19, 2010
  • Sep 19, 2010
Have you pulled codes yet? Pay attention to any idle-control/IAC codes. Are there any vacuum leaks?
F
fox182
17
  • Sep 19, 2010
i just replaced the computer which was fried, i havent pulled codes yet i checked the vacuum lines nothing seems to be wrong there,its almost as if something kicks on, or off and drops the ldle a bit
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 20, 2010
  • Sep 20, 2010
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
