idle problem
  • Thread starter Thread starter 90 GT
  • Start date Start date Jul 21, 2004
90 GT
12
  • Jul 21, 2004
i own a 1990 gt and have a problem with it idleing steady.the gt basically for now has mac long tube headers and 373 gears in the back.i just gave it a fresh tuneup (plugs wires distributor cap and rotor).i tried adjusting the throttle screw and i brought the idle up to 1000.like a few days after the revs dropped to about 600 and it goes up 800 and back down again ,i have no idea what would cause it to do that.any help out there i'd really appreciate it. thanks
HISSIN50
34
129
Jul 22, 2004
  • Jul 22, 2004
the computer will adapt. so if you manually raise the idle, it will eventually figure it out and try to get it back down to stock idle specs. because things are out of whack, it can cause surging and other issues.
some have disconnected the IAC - i have not and dont know how effective that is.
just some info. good luck.
blackstangt
460
ny
Jul 22, 2004
  • Jul 22, 2004
it's not supposed to be at 1000 at idle. The computer is adjusting to get back down to 650-700 rpm which is the comp set idle. Also, try disconnecting the neg for 15 mins, and set the idle to 700.
gungfusemaj
211
Bradenton Fl
Jul 22, 2004
  • Jul 22, 2004
Black is right 700 Rpms make sure your TB sensor is set at the right voltage.
bsedwebt70-5.0
320
Charlottesville, VA
Jul 22, 2004
  • Jul 22, 2004
clean your tps - take off your air intake tube that goes to the throttle body and go to town - you will find if you pull off that little 2 bolt on thing at frt of the throttle body area that allows the gas to return (EGR) it will be coated in carbon inside - take it off and clean with carb cleaner - works every time - takes about 10 minutes with an old toothbrush and rags - I wish I knew better how to describe it
ironmedic
1,361
Puyallup, WA
Jul 22, 2004
  • Jul 22, 2004
also check your TPS voltage!
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Jul 22, 2004
  • Jul 22, 2004
try this.. it worked for me when i had this problem
http://www.fordmuscle.com/archives/2002/01/tenpin/index.shtml
90 GT
12
  • Jul 22, 2004
guys thanks alot for the help.i still have a problem with the tps sensor reading at 1.1 instead of it being in the .98 .99 range.i cant get it to go any lower than 1.1 and i don't know what to do next.
$uperstang
476
Detroit, MI
Jul 22, 2004
  • Jul 22, 2004
I had the same problem with mine. If your car is surging at stop lights (funny idle) just replace the TPS all in all and you'll be fine.
HISSIN50
34
129
Jul 22, 2004
#10
  • Jul 22, 2004
  • #10
IIRC, the puter zeroes the TPS reading out at start up, each time. as long as the static reading is ~1.30 volts or less, it is immaterial (per Michael and Stang & 2 Birds).
that said, some have diminished surging and such, by dialing the static TPS reading down from slightly over 1 volt to below.
good luck.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
T
Resolved No run or idle
  • Thebluefox1
  • Oct 10, 2025
Fox 5.0 Mustang Tech Nov 25, 2025
DadLife0724
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
