I don't mean to jump your post but I'm having an idle issue too.
I haven't had a chance to run the codes. Probably this weekend.
As far as the pcv goes, I've got a Cobra intake, and I don't know if it's harder than a stock intake, but it's next to impossible to get to the *#$* pcv, grommet, and screen. I found that once you get the valve and the grommet out, you can use a pick up tool.
The kind that has a long spring for a shaft, and a claw that expands when you push the button on the end. I stick it in the hole, push the button to let one of the hooks grab the screen, let go the button to retract, then pull it out. Works real good.
Good luck with your car.
