Idle Problems.. new thread for problems
Im thinking more of the cts, I had that problem with my trans am. It tricked the computer into thinkin it was cold when it really was hot. I havent read all the reply's so i dont know exactly where your at.. but i'd pull it out and take a look at it anyways. you could possibly have a short in the wire somewhere or maybe a bad sensor
It is the main EFI body wiring harness. See the digaram for what a typical 5.0 fox Mustang EFI body harness looks like. You will see that it connects to almost everything under the hood.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
Ignition switch wiring
Fuel pump, alternator, ignition & A/C wiring
Computer, actuator & sensor wiring
Fuse panel layout
Vacuum routing
Split the harness open in the area of where connectors, 20,21 & 29 join the main harness. The splice for the black/white signal ground should be in that area.
Dude...i checked in on this thread about a month ago. Jrichker is one patient man helping you out like this. this thread makes me wonder if you even look at the links he gives you. Its all right there...just read the stuff and fix the problem. There's only so many things it could possibly be! Those diagrams are awesome and very detailed....and in COLOR. shouldnt be that hard to follow his instructions and do some testing/diagnosis by yourself.
You will never learn how to diagnose/fix car problems if you ask someone to hold you hand the whole time.
