Idle problems
  • Thread starter Thread starter white93LE
  • Start date Start date Oct 12, 2010
W
white93LE
Jerzey
Oct 12, 2010
  • Oct 12, 2010
Ok I know this has been asked a million times....
I have been having a high idle problem, I can not get it below 1,100-1200rpm.
I have cleaned n replace the IAC, cleaned the TB n EGR spacer, tried clocking the mass air sensor, checked TPS voltage (0.89), also tried 2 reset base idle by disconnecting the battery for 30 mins, IAC un-plugged, ect, ect...Still cant get it below 1,100. The only thing I can think of, is the TB blade is worn n getting blow-by? Besides the idle it runs great. What little mods I have include: UPR in fender cold air intake, off road h-pipe, mac equal length shorties, elect. fan, new alt., new cap n rotor etc... The motor was replaced recently, but kinda had idle problems w the old motor also. The new motor was heads, block, lower intake. Everything else stayed the same. So I assume I transfered the problem from one motor 2 the next. HELP...
Thank you
I also changed the ACT, and ran codes...codes= 94 AIR system inop, 44 AIR system inop, 13 idle speed or air bypass not controlling idle. I took the iac apart n was very clean n free moving. Did not see the iac motor moving at all. Not sure when it should move though.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 12, 2010
  • Oct 12, 2010
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
W
white93LE
Jerzey
Oct 12, 2010
  • Oct 12, 2010
I have done 90% of whats on there an still cant figure it out...I am just tired of trouble shooting at this point...Just hoping someone had the same problem and can help.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 13, 2010
  • Oct 13, 2010
Can you do the mechanical base idle set procedure as described in the Surging Idle Checklist? I'm not talking about someone else's idea of how to set the base idle, but the exact procedure as described in the Surging Idle Checklist.
That will tell you if the problem is mechanical or computer related.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Oct 13, 2010
  • Oct 13, 2010
Have you run the codes?
HISSIN50
34
129
Oct 13, 2010
  • Oct 13, 2010
Bottom of post one. 44, 94, 13
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Oct 13, 2010
  • Oct 13, 2010
Damn...I looked fpr that too and still missed it.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 13, 2010
  • Oct 13, 2010
The code 13 is the clue - someone has jacked the mechanical setting up past the point where the computer can no longer control the idle.
Code 13 Key on Engine running - Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high)
If your idle is above 725 RPM, the computer will set this code. Normal idle speed is 650-725 RPM. Higher than that may mean that you have a vacuum leak or someone has mechanically set the idle speed by use of the idle speed screw. This effectively disables to computer’s ability to control idle speed.
Like I said before, can you do the mechanical base idle set procedure as described in the Surging Idle Checklist? I'm not talking about someone else's idea of how to set the base idle, but the exact procedure as described in the Surging Idle Checklist.
W
white93LE
Jerzey
Oct 14, 2010
  • Oct 14, 2010
Yes I did. I disconnected the battery for 30 mins to clear all codes, disconnected the IAC, radio, lights, etc=off. Car was warmed up, still can not get below 1,300rpms. The idle screw can not go out any further, thats as low as it goes. I dumped almost a entire can off carb cleaner looking for vacuum leaks. NOTHING. I turned the IAC upside-down, idle got worse. Clocked the MAF, nothing. I have been playing with 87-93 stangs for 15 years, never had a problem like this. I am down to 3 things, 1) faulty IAC (doubtful, only a year old, and even if it was bad I should be able to get it below 1,300rpm with it disconnected) 2) worn Throttle body plate (never heard of them wearing but read it somewhere) 3) tight valves (doubtful, valve covers never been off this motor) The motor did sit for 2 years in a garage, and has 37,000 miles on it. But far as I know it has not been touched. This is driving me crazy........ Oh it also could be a sensor or computer.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 14, 2010
#10
  • Oct 14, 2010
  • #10
Did you remove the SPOUT when trying to set the base idle? With the SPOUT removed and the IAC disconnected, the computer is no longer controlling the idle. That means you have mechanical problems.
Mechanical problems break out into 3 areas
Vacuum leaks-some of them are very hard to find. Spraying flammable liquids or gases to find vacuum leaks is asking for a flash fire. They do not find leaks on the underside of gasket surfaces. Inspect the PVC valve plumbing and grommet, it is very easy for the grommet to leak or the hose to crack. The small vacuum lines are also prone to cracking and leaking.
If the lower intake manifold has been removed, there is a good chance that the gasket slid out of place then it was reinstalled. That makes vacuum leaks that suck air form the lifter valley and cannot be found without removing the lower intake manifold.
Binding throttle linkage - pop the throttle linkage off the throttle body. It will pry off using a screwdriver between the linkage and throttle arm. Check the idle and see if it changes. Try to change the idle speed by twisting or wiggling the throttle arm. Be sure you have backed the mechanical screw all the way out, almost to the point of falling out.
Throttle butterfly - if it binds or the body or throttle shaft is excessively worn, it will cause idle problems. Some throttle butterflies have a hole drilled in them to change the idle. If so, clean the area around the hole and cover it with bubble gum as a test.
W
white93LE
Jerzey
Oct 14, 2010
#11
  • Oct 14, 2010
  • #11
I double checked base idle, and yes this time I did take the spout connector out. I missed that the first time. No change.
The lower intake has never been off that I know of, the PVC seemed to fit fine when I installed it with this motor.
I kinda had a feeling it is the butterfly, but wanted to exhaust all my options before I bought a new TB.
H
Haus
408
#12
  • Oct 15, 2010
  • #12
If your idle goes to normal if you cover the hole in the throttle body...what does that tell me?? I had idle issues too and noticed when the hole was blocked. no more high idle and I can finally adjust the idle
W
white93LE
Jerzey
Oct 16, 2010
#13
  • Oct 16, 2010
  • #13
I dont have a hole in my throttle plate. Thanks for the idea tho.... I think the throttle plate just is worn n gettting blow-by....
H
Haus
408
#14
  • Oct 16, 2010
  • #14
haha that was actually a question from me lol I was actually curious about that since he mentioned the hole in the throttle blade
W
white93LE
Jerzey
Oct 16, 2010
#15
  • Oct 16, 2010
  • #15
OK I lied it does have a hole...I forgot...haha...bought a new TB n EGR spacer for $30....Idle problem solved...It does have the TPS n IAC on it so still dont know which of the 3 it was...But who cares, idle set at 750rpm n I am happy again.....lol
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 16, 2010
#16
  • Oct 16, 2010
  • #16
Remember the bubble gum trick - you may need it someday....
W
white93LE
Jerzey
Dec 28, 2010
#17
  • Dec 28, 2010
  • #17
I will keep it in mind...thanks...
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
