  • SN95 V6 Mustang Tech
Idle surge
  • Thread starter Thread starter Shaggydog2000
  • Start date Start date Nov 14, 2005
Shaggydog2000
20
  • Nov 14, 2005
I have a manual 2000 mustang V6, and the idle surges up about 200 rpm every thirty seconds or so. I notice it in neutral, and in gear with the clutch in. Is this a common problem? Is there a common fix, I only noticed it recently in the cold weather?
TMX
Houston
Nov 15, 2005
  • Nov 15, 2005
Could just be the engine warm up. I haven't had my V6 in cold weather yet, got it 4 months ago and it is still 80+ in Houston. But my older 93 stang would do that when it finally got cold down here.
Shaggydog2000
20
  • Nov 25, 2005
I replaced the battery (it was the orginal that came with the car 6 years ago), now it idles smoothly. Cold probably brought out my battery problems, it was beginning to crank for a while before turning over too, so I just figured I'd replace it now before it becomes a refuses to start when it's 10 degrees out, there are three feet of snow on the ground, and I'm late for work.
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
D
SN95 V6 1994 occasional rpm surge while driving---where should I start?
  • DPP
  • Aug 30, 2025
SN95 V6 Mustang Tech May 5, 2026
DPP
D
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
SN95 V6 Mustang Tech Apr 30, 2026
badmech
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
