  • 1994 - 1995 Specific Tech
Idle/TPS Question.
  • Thread starter Thread starter 91LX_5L
  • Start date Start date Apr 10, 2005
91LX_5L
1,943
British Columbia
Apr 10, 2005
  • Apr 10, 2005
I know lots of you say 94-95s reset their own comptuers on the TPS so adjusting it wont matter. Well we adjusted on my buddies stang and it worked like a charm.
BUT
I have messed with my cars idle screw, tb bleeder screw too much and now im lost. I have a bad hanging idle which is caused by the TPS. The lowest I can get it is 1.03 and thats even with the holes drilled out as big as they can go.
NOW when my volt meter was hooked up I noitced when I adjusted the idle stop screw that it effected the TPS. Should I adjust this as far out/in so that my TPS reads .98ish then try to get my car to idle from there???
(its will idle way too low when I do this but then mabye I can mess with my throttle body screw to adjust the idle?). Anyone following me? Or is my TPS sensor faluty?
Anyone have any tips? I had it decent for a bit reset my comp etc but then It was a bit too low of idle so I touched the throttle stop screw and now its very bad again.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 10, 2005
  • Apr 10, 2005
Do a search for "hanging idle". You will find a link on how to reset your idle correctly.
Scott
91LX_5L
1,943
British Columbia
Apr 10, 2005
  • Apr 10, 2005
I've read almost all of those.
What I want a opinion on is
Should I adjust the trottle stop screw as far out/in so that my TPS reads .98ish then try to get my car to idle from there??? My tps is allready set as low as possible but isnt low enough yet.
HISSIN50
34
129
Apr 10, 2005
  • Apr 10, 2005
i would rather have the idle stop screw adjusted properly and deal with the TPS after that, than use the idle screw to accomodate the TPS.
good luck.
91LX_5L
1,943
British Columbia
Apr 10, 2005
  • Apr 10, 2005
well ive adjusted the tps as far as it goes i even drilled out the holes big as possible...
rgs
124
Vancouver, Canada
Apr 10, 2005
  • Apr 10, 2005
matt when ur done with yours, FIX MINE
HISSIN50
34
129
Apr 10, 2005
  • Apr 10, 2005
are the SN TPS's and puter really that sensative? im a lot more savvy with foxes, and it really makes not a lick of difference on those (per datalogging).
i would be sure there are no vac leaks or other issues, and then start over, not unlike the steps in this article (which im sure you have read):
http://www.muscularmustangs.com/iac.html
good luck.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Idle issues….again.
  • Nostang25
  • Sep 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 7, 2025
AeroCoupe
Engine Base Idle Reset-Accufab
  • 89notchDude
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 22, 2025
Scrapla347
