  • SN95 4.6L Mustang Tech
Idle Trouble, Advice Please
  • Thread starter Thread starter Reefmonster
  • Start date Start date Aug 9, 2011
R
Reefmonster
  • Aug 9, 2011
Car is a 99 GT, bone stock except flowmasters. My trouble is when I have the IAC plugged in it idles at about 2800-3000rpm, and the Service engine light is not on. But when I unplug the IAC it idles about 700rpm, and will cut off everyonce in awhile and the service engine light comes on with it unplugged I have replaced the IAC, MAF, and the TPS. Nothing seems to fix the problem. Does it need to go to the shop or do you guys have any other advice?
R
Reefmonster
  • Aug 9, 2011
It is a straight shift too.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 9, 2011
  • Aug 9, 2011
700 is too high with the IAC disconnected. Either the idle stop set screw is set too high or there's a vacuum leak (or both). With the IAC disconnected, the idle should be so low as the motor is on the verge of quitting (or it should die outright).
When was the last time the PCV valve was changed? Check valve covers, oil dip stick, PCV lines, fittings. In sort look for any source of un-metered air.
Check out the following for more informaton:
Is your mustang stumbling, dieing at idle or idling rough? - Page 14 - Ford Mustang Forums
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
