Idler arm spacer?
  • Thread starter Thread starter pianoman
  • Start date Start date Sep 6, 2021
P
pianoman
Sep 6, 2021
  • Sep 6, 2021
When redoing the front end of my 69 I noticed a homemade spacer between the idler arm and the frame rail about 1/4 inch. I removed it when reassembling everything because it didn't belong. On another forum I found at least 5 other cars with the same mod. That make me think it is some kind of old school mod to improve the geometry like the Shelby drop or the quick steer kits from the 65-66"s. Does anyone know anything about this?? Thanks
horse sence
8,564
233
Wile Coyote's stunt double
Sep 6, 2021
  • Sep 6, 2021
I have seen them ,i believe it was because the frame rails were to far apart throwing off the ideler arm and the pitman arm so a spacer was use to align them
P
pianoman
Sep 7, 2021
  • Sep 7, 2021
thanks for the reply. That make sense but since it works with or without the spacer, do you know what kind of difference it's supposed to make in steering response?
horse sence
8,564
233
Sep 7, 2021
  • Sep 7, 2021
Well ,the idler and pitman needs to be parallel ,so apparantly they are not so the spacer must be to remedy that . Not sure if that much could throw off the geometry or not but that is why i figure the spacer is there . All the spacers i have seen are around 1/8 inch thick but i suppose slight frame rail damage or faulty placement from the factory could have required the spacer
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Hello fellow Mustang fanatics.
  • 580HP*428Cj
  • Apr 2, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 18, 2026
josep4
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
