Idling problem
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Sep 30, 2004
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Sep 30, 2004
  • Sep 30, 2004
OK I did a search but found nothing. I put Valve covers and a 1/2 inch spacer on my car this weekend now the car idles high in park or neutral about 1700rpm's and 1000 rpms in drive. Is there an easy way to fix this. I dont have a voltometer so that is out of the question i know its probabbly easy but i just cant figure it out The car is an 87 speed density all stock AOD.
nito88stang
2,012
Fullerton, California
Sep 30, 2004
  • Sep 30, 2004
Back out the idle adjuster screw under the throttle body. If you back it out all the way and the idle is still to high you'll have to reset you idle. Here's how to do it.
http://www.corral.net/forums/showthread.php?s=&threadid=10805
J
jerry beach
2,671
Ocala,FL
Sep 30, 2004
  • Sep 30, 2004
Why did you do that?
Did you torque the intake to specs with a torque wrench?
Check for a vacuum leak. Use a vacuum guage, it will come with instructions. 18-21 in. hg. is what you should read at idle on a stock engine. Otherwise you are looking for what is normal for that motor.
Re-check your work first, you know it is something that you messed with. did you label stuff first? Replace any vacuum lines?
HISSIN50
34
129
Sep 30, 2004
  • Sep 30, 2004
did ya create a vac leak?
good luck.
RsStanG1987
569
9
79
Dupont PA
Sep 30, 2004
  • Sep 30, 2004
i replaced everything where it was and put one back on that was broken everything is right exactly where it was. I torqued it right according to the book.
nito88stang
2,012
Sep 30, 2004
  • Sep 30, 2004
Yeah, now that i look back at your post, that much of a jump in idle just for an intake spacer is most certainly a vacuum leak.
RsStanG1987
569
9
79
Dupont PA
Sep 30, 2004
  • Sep 30, 2004
I found the problem i over looked the hose that goes from the back of the lower intake to the upper. I think its the pcv valve. Any way that fixed the problem. It always sucks when you forget something that you know you have to put back on then forget it exists. Any who thanks for the help..
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
