KBCobra95 said:
well after playing with the idle screw i got it to idle around 850-900 rpms. I took it out for a spin last night but when stopped and turning the wheel it would die? Why would it do that? Thanks.
Dadgummit
I had some info all typed up for you and my puter decided to freak on me
after thinking all that stuff up and everything
Here is a brief version of that original post.
The example you give and others like
Turn ac on
Put car into drive
etc, etc, etc
Anything that will put a load on your car at idle and cause the rpms to drop or rise a bit is all about what the isc (idle speed controller) is used for.
I know ya'll call it something different but I can't recall the leters.... you know what I'm talkin about, lol.
The isc sends a signal to the pcm that is uses to judge airflow. The pcm uses a table of airflow/rpm values to determine how to adjust your idle speed for a somewhat constant level when those different conditions come into play.
Say you put some hot rod parts on your car (which we all do, lol). That can be where things start to get all hosed up cause the airflow from the mods has most likely changed things to the point that those values in the pcm's isc table are no longer accurate.
The mods alone can cause issues.
If you got things goin on that are not normal like v leaks, electrical connections, and the like (which we all know can happen after a major upgrade like h/c/i) ...... those things can all the more compond the problem of the pcm NOT being able to compensate.
If I were you, I'd make sure all the above stuff is like it should be and when you are sure EVERYTHING is as it needs to be .......................
Disco the batt for a pcm reset and give the pcm a few days for its adaptive strategy thing to learn under all of those various conditions and see how things turn out for you.
Who Knows ??? You may or may not get lucky
And be one of the few who has found the ..............................
Ever Elusive Stable Idle
Grady
