  • SN95 4.6L Mustang Tech
Idling problems
  • Thread starter Thread starter bdp55
  • Start date Start date Jul 18, 2006
bdp55
25
  • Jul 18, 2006
Hey guys, I have a 2000GT, it idles really rough, when I start it up it is fine until it gets to running temp, then it goes crazy, it almost dies and then it revs itself up to about 1500rpm, it does this back and forth until it finally dies, The Throttle adj seems to be okay, and I haven't done any major upgrade for a while, this just started, any ideas on what it could be?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 18, 2006
  • Jul 18, 2006
I think primarily it is low on freon and needs some general preventitive maintenance like being SeaFoamed all three ways, cleaned IAC and MAF, and reset PCM.
Outlaw97GT
234
Redneckville, Tx
Jul 18, 2006
  • Jul 18, 2006
You might wanna check out your TPS also.
+1 On what Trout said too.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 18, 2006
  • Jul 18, 2006
Oh yeah, TPS... That's probably the problem, did not think of that.
K
Keldog
Oak Ridge, TN
Jul 18, 2006
  • Jul 18, 2006
What in the world could a vehicle being low on freon possibly have to do with why a vehicle's idle is rough and dying? That can cause the compressor to kick on and off but it shouldn't cause the vehicle to shut off. Cleaning the throttle body, IAC and MAF can possibly fix it but I would also check to make sure you haven't had a vacuum line or other intake hose possibly work itself loose. At a higher rpm the engine will run smoother as vacuum increases but at a lower rpm like 800 or lower escaping air can cause a rough idle condition. Since you didn't mention your check engine light coming on or loss of performance my guess would be an intake leak of some sort.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 18, 2006
  • Jul 18, 2006
Low freon cause the idle to fluctuate. Combine this with dirty IAC and it will cause the problem descibed.
Anyways, it is probably the TPS.
If I am wrong I will give him his money back
K
Keldog
Oak Ridge, TN
Jul 18, 2006
  • Jul 18, 2006
tps is a good point. I would just eliminate the simple stuff before adjusting or replacing anything. I work for an auto parts place and I see so many people who ignore this point before laying down hard cash.
bdp55
25
  • Jul 19, 2006
what else?
Okay guys, I took it to my shop that tuned my car previously and they can't figure out what it is either, he's cleaned all the sensors, even tried replacing most of them (TPS, MAF....) but but the problem won't go away, he said he can't find a vacuum leak either? Any other ideas?
SilverBullet00
1,150
Wichita, KS
Jul 20, 2006
  • Jul 20, 2006
I have a similar issue. What mods are you running?
bdp55
25
#10
  • Jul 20, 2006
  • #10
I've got a procharger with a D1 head at 10lbs of boost, 75mm T/B, 75mm plenum, intake spacer, BBK shorty headers, x-pipe, flowmaster prochamber exhaust....and others that don't effect the motor like shifter, suspension....
The guy working on it took it to a ford dealer to have them run a diagnostic and they said that every cylinder is mis-firing, both at idle and under load...there are brand new spark plugs, coils, injectors...they did a compression test and everything checked out. They cleaned all the sensors, nothing. They can't find a vacuum leak or anything like that, the dealer thinks it's an electrical issue? All I know is I'm getting screwed with a huge bill when they don't even know the problem yet. Also my car use to make about 410 rwhp, but now since this happened it only makes about 330 rwhp. I just hope they figure it out soon!
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
