  • SN95 4.6L Mustang Tech
Idling Problems
  • Thread starter Thread starter brtnstrns
  • Start date Start date Nov 15, 2010
brtnstrns
606
11
Lewisville, TX
Nov 15, 2010
  • Nov 15, 2010
My car is idling really badly, sometimes almost stalling out when I'm coming to a stop and put the car in neutral (manual transmission). I replaced the IAC within the past 6 months due to similar, but much worse issues. Is there anything else I can do to get better idling performance, such as something with the computer or anything else? Thanks.
GDawg
1,469
Nevada
Nov 16, 2010
  • Nov 16, 2010
Check for vacuum leaks... that's most likely it.
trinity_gt
3,125
81
99
Canada
Nov 16, 2010
  • Nov 16, 2010
Things to check include the usual vacuum lines but also check the duct running from the MAF to the throttle body for cracks down in the corrugations.
Also check the PCV valve. If it's stuck or not sealing well it can constitute a vacuum leak too.
If no obvious external vacuum leak can be found, you might want to remove the EGR valve and check for carbon build-up that might be causing the valve to stick in the open position.
brtnstrns
606
11
Lewisville, TX
Nov 16, 2010
  • Nov 16, 2010
Awesome. Thanks guys I'll be sure to check all that out.
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
K
2003 GT High Idle, vac leak process
  • krysber
  • May 11, 2025
SN95 4.6L Mustang Tech May 11, 2025
krysber
K
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
