idling rough ...grrr
  • Thread starter Thread starter zeusmoto
  • Start date Start date Feb 27, 2004
Z
zeusmoto
390
utah
Feb 27, 2004
  • Feb 27, 2004
hey guys do you know what the problem is when your car is idling rougher than usual, i have no idea why it just started all of a sudden, damn. also i am trying to replace my window motors but the thing that sits in front of them is riveted on, how do i replace them if they have a riveted panel in front of them
thanks
jerry
89lxsport50
550
Franklin Tennessee
Feb 27, 2004
  • Feb 27, 2004
If you are talking about a Fox Mustang, remove the door speaker first. Then there are 3 bolts holding the motor in. Remove those and the motor will come right out through the speaker hole.
As for the rough idle, it could be any number of things. Pull your codes first and go from there. Also do a search on rough idle.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Feb 27, 2004
  • Feb 27, 2004
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
Mavrick
2,264
Collingwood, ON
Feb 27, 2004
  • Feb 27, 2004
For the rough idle, i'd first try cleaning your IAB with a can of carb cleaner. Only takes a couple minutes, and you can re-use the old gasket.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
