Idol and running problems?!
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Nov 7, 2007
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Nov 7, 2007
  • Nov 7, 2007
When i first start the stang weather warm or cold it dosent idol i have to keep giving it gas. Then once it warms up it idols but at like 800-900. Then also it backfires threw the intake while driving, it does this in almost every gear and the majority of the time and no matter how much throttle i give it? Easy throttle it eccelerates kinda sluggish and hamer down it will gooo! I have all bolt ons and heads cam intake. I just installed new autolite plugs and they are gapped correctly. peace
john
Flavadave4
1,044
21
49
Utica, NY
Nov 7, 2007
  • Nov 7, 2007
TPS or MAF problems?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 7, 2007
  • Nov 7, 2007
See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=698148
for help with your idle problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
Backfiring out the intake is either a valve stuck open or a lean mixture or spark plug wire(s) connected to the wrong cylinder(s). Check compression on all cylinders and then look for vacuum hoses loose, cracked, or misconnected. Check the line for the vapor recirculation system – it is easy to knock loose and not see it when you connect the air pump plumbing. If the vacuum line for the EGR valve and the air pump are cross connected, some very strange things can happen. Check the mass air flow electrical connection and see that it is tight, the same goes for the fuel injection wiring harness connectors up on top of the manifold near the firewall.
Sticking valves: If a intake valve is bent, has a bad spring or is misadjusted, the engine will sometimes backfire through the intake. Use a vacuum gauge connected to any convenient spot on the intake manifold. Run the engine at 1000 RPM & look for 18-21 inches of vacuum with a steady needle. A problem intake valve will make the vacuum gauge needle sweep 5-10 inches.
Lean fuel mixture breaks out into several sub categories:
A.). Vacuum leaks
B.) Air entering the intake without passing through the MAF.
C.) Failure of the MAF, BAP/MAP (Baro or Manifold Air Pressure, same sensor, different name), ACT (air charge temp), or ECT (engine coolant temp). These should set a code in the computer.
D.) Leaking exhaust gases from EGR valve at WOT or EGR opening when it should not be open.
E.) Poor fuel delivery due to bad fuel pump, clogged filter or bad fuel pump wiring. Look for low pressure or fluctuating pressure. Standard injector pressure is 39 PSI at idle, with the vacuum line disconnected from the regulator and capped.
F.) Clogged fuel injectors.- see the cylinder balance test below
H.) Fuel injector wiring problems causing injector not to deliver rated flow.
I.) Computer problems: (computer problems are not common like sensor problems)
J.). ROM has bad data in fuel or timing table. This should also set a code in the computer.
K.) Failure of one or more of the computer's driver transistors for the fuel injectors. No code set on this one. Use a noid test light to test the injector wiring & injector drivers,
L.) MAF calibration off or mismatched to injectors.
M.) ACT or ECT bad. Sometimes the sensors will be off calibration, but not bad enough to set a code. If they falsely read too high a temp, the engine will back off fuel delivery.
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
LOOK for a vacuum leak. It is probably the cause of both problems.
F
Fox8950
247
Nov 7, 2007
  • Nov 7, 2007
+1 on the vacuum leak, bust out the starting fluid see what you can find
N
Need stainless carb heat shield
  • newmex999
  • Aug 29, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2026
Mcmahst
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
L
2004 Mustang GT issues after bolt-ons added
  • Leo090
  • Nov 1, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 24, 2025
Leo090
L
Engine Help hard/no start runs rough.
  • Mr.Kelley
  • Dec 24, 2023
  • 2 3
6K
Fox 5.0 Mustang Tech May 19, 2024
manicmechanic007
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
