Do you think I could safley go the welding/modifying route? IMyke86GT said:Custom axles and drums/rotor's would eb a start. Or take a stock type axles have them redone for six lug, byy welding up the 5 holes and redrilling for 6 in the bolt pattern you want. And doo the same for the rotos/drums.
88GT17MA said:yes, would it matter if it wasnt?![]()
vristang said:In my opinion you would be time and money ahead using common 5 lugs. They are plenty strong enough, and you could surely find something lighter than the viper wheels. The parts are easy to find and there are plenty of people who can help you with the conversion.
vristang said:My only suggestion would be to look at Fords heavy duty vehicles (1 tons and bigger). I am pretty sure they will have 6 lugs or better. These vehicles will not be using the 8.8 though. Maybe it would be easier to switch to the heavier 9" rear. Whatever the case, the odds a Ford bolt pattern will be the same as the viper wheels are not in your favor. Why not use the viper rear end?
vristang said:If you do go with custom fabrication, I would only talk to shops that fabricate axles on a daily basis. Make sure they know that this car will be raced and that strength is the ultimate concern. Having the local welder cut and paste axles together seems pretty dangerous to me.
This thought came to my mind too. Have you thought much about actually physically fitting those huge tires/wheels in the back of your Mustang? Sure it would look cool, no doubt, but you're most likely going to have to mini-tub it and get a fuel cell. Do you know the backspacing on those wheels? Have you checked around for repro viper wheels? There are a few companies that make reproduction wheels in different sizes and different bolt patterns than stock. You could possibly buy those wheels in a 4 or 5 lug pattern that would fit your current rear end and get some 9-10" wide wheels for the back and throw some 275 or 295's on it and call it a day.vristang said:I just saw how big the tires are. I have 275s in the back of my GT, and had to use a hammer to get them to fit. The 255s in the front are even worse. Do you plan on swapping out the entire upright in the front? Maybe you could use the truck that the wheels were on as a donor car, or find a wrecked one.
