If you had 5000 to spend.. how would you.
If the motor is healthy, I would go Kenne Bell 1500 @ 6psi + supporting equipment as well as a TwEECer R/T. That should land you right around $4-5,000. If you want a real project and don't mind spending twice as much time, a budget turbo kit would be kick ass.
I wouldn't get a Blozilla only becuase the 1500 is more efficient with boost under 10psi and if you plan to run more boost than that, you better build up the rest of the motor which would put you way over the 5k budget.
Honestly i would dump that straight into the motor and worry about suspension later on. I would rebuild my whole motor to be able to push 400hp NA. Yeah that's alot but it's my goal without any power adders. And once i'm done with everything on my car and i would install nitrous just for looks. :D Btw i'm not one for pushin the button lol
351 swap done right. Anything left would be for suspension and possibly a new rear.
OR
A new 302 (or 306, 331) that is N/A, makes a lot of power (H/C/I), AND setup to pass emissions. I'm not sure just how much power one could make setting up a fresh block with new parts, considering that I need to pass emissions and want to remain N/A. Maybe the best thing would be to rebuild my motor, upgrade the intake and add a Vortech. With $5K, I would have reason to find out what my options are.
Here's what I'm thinking
Fox Lake 306 Shortblock to replace my 107000 mile motor (that has NO problems just want to replace it for good measure) H/C/I...
If anyone has any suggestions feel free to chime in.
107k isn't necessarily high mileage :D. But replace it if you want :nice:. $5k goes damn quick when you start throwing it at the motor. I spent more than that, and I didn't replace the motor :).
If I were going to limit myself to $5k, I'd do the H/C/I again. If you could afford more, then I'd get some better heads, GT40's would probably be good 'nuf, and then slap a turbo kit. That clears $5k real fast though, 'cause you'll need a TKO to handle the power (add $1700).
Dave
