QDRHRSE
This is turning into a great thread! You make a lot of good points however you are still overlooking a couple of things. A blower does run hotter but under normal driving conditions a blown car with 7-10 degrees of initial timing will run cooler than an NA car with 15-18 degrees of timing and will detonate less. My own car is the best example I could use. I have a pretty stout motor with a small blower and I run a black magic fan which is rated for less power than my car has, and also, I run a stock radiator, I live in the desert, I have all of my emissions equipment (eventhough that is temporary- its on there). The car never goes above 180-185 unless the blower is making a lot of boost. I have seen the temp gauge in the car go up to the halfway mark at the track only. Not one of my other cars that was NA could do that. I've had a a lot of Mustangs......
A base kit with an Anderson Power Pipe will make 7-8lbs of boost and a car with exhaust on it will most definitely see 80rwhp. Tuning a small blower is easy. It only becomes difficult when you start to make a lot of boost. Re-gapping the plugs and pulling back the timing are the only things you would need to do. You might have to change the diaphram in the FMU but usually the one in the kit is perfect (they usually ask you about your setup when you buy the blower)
I wish I could remember which magazine it was, but one of them, within the last year did a dyno test based on the same thing that we are "discussing" and the blower car made a good deal more power. I know people on StangNet have referenced it before....I would bet that you read it.
A blower does respond to bigger injectors,MAF...etc. etc., however, a base kit is designed to work with a stock motor with stock everything. I think the only strong recommendation that Vortech makes is installation of a higher volume [bigger] fuel pump.
H/C/I will not make significant hp increases without a larger tb or mass air meter. This point alone is undeniable. The blower creates its own atmosphere and pushes the additional air in by force so a tb is definitely not as important.
I will close with a short story. In 94 or 95 we bought a 91LX. With exhaust only it went 15.2x's on radials. We then bought a paxton SN-93 supercharger, bolted it on, went to the track the same night and ran 13.5x's, once again, on radials. We didn't know anything about EFI back then either. You can't do that NA with motor parts only for 2k but I bet there are bunch of guys here on StangNet who have similar stories about superchargers.
I guess ya'll weren't scared to flog on it without a tune. Speaking of without a tune...I can't see how you gained that much and it wasn't truely tuned so to speak
