If you had a stock Fox 5.0 efi motor 5spd trans 3.73 gears what would you do to make it faster without nos or boosting it?
Good tune-up, play with the timing
Headers, H-pipe
A/C Delete and remove smog pump.
All of thats a great start and cheap.
GT40 heads
Trick Flow Stage 1 cam
Cobra or better intake and supporting throttle body etc
That combo right there with the usual tricks here and there like running a short belt, electric fan, gears, pulleys, etc, will get you a 12 second car on slicks.
Ok i have a set of 69 302 heads # dooe would these be good
Do you know off hand what the bowl cc is and what size valves they have in them? They're a pretty decent flowing head as far as the casting but they could use larger valves more than likely. Now if you had some 289 HiPo heads that you could do a little port work to and but in 1.94 intake valves, you'd have some really healthy heads that would bump compression up quite a bit.
