If you were to choose....
65notch
303
661 Cali
say you have a lump of money(not a whole lot but some) and want to put into a transmission. you start with a 65 289 w/ a C4 and want to go with something better like a Tremec 5spd or AOD...which one would you choose and why? what driveshaft mods would you need to do for the 5spd?
thanks guys
thanks guys
Depends on what you want to do with the car. What is your goal with it ? Cruiser ? Street/Track ?
gzminiz said:
I would always choose a 5 spd. I feel like i have more control and more "one with the car" with a stick. But that is personal preference and has absolutely no facts to back it up or stats.
i feel the same way. i actually have an AOD, it just needs to be rebuilt. so by for the cheaper way to go is the AOD, but if im going to do all the work i rather spend the more money if i need to get what really is better. im figuring about 3k for a 5spd swap and like 1500 for the AOD. does that seem about right?
since you like to run hard, and play in the corners, sell the AOD and get a 5spd. depending on the level of mods you are planning, the "Z" series T5 would work nice on a mild 289(say up to around 350hp max). more than about 350hp you want a tremec 3550. if this were going to be a drag car, then i say build the AOD. automatics dont like the constant up and down shifting like that done on a road course, or running the twisty canyon roads, especially the AOD. you can do a 5spd swap for less than $3k though, depending on how much you pay for the 5spd to begin with.
how would you get away with doing it under 3K? most of the 5spds ive seen are starting at 1400 or so. then the clutch and all the converssion parts. do you normally need a longer or shorter driveshaft?
hydraulic or cable clutch?
you could do a tremec tko 600 swap for less than 3 grand....
Tremec TKO 600 - $1600
Geforce Z-Spec Clutch - $250
Billet Flywheel - $200
Cable clutch Mods (including clutch pedal) - $250
Shorten Driveshaft - $80
Bellhousing with fork - $150
that comes out to only $2500
i like that price a lil better.
so...cable or hydraulic clutch?
I did my T-5 swap for less than a grand. I think I've mentioned that here before.
All eminently doable if you are willing to use good used parts.
Historic is smiling right about now..... ;)
btw, just to keep my "azzhole" badge, the T-5 swap has been discussed a zillion times (including 2-3 times in the last 10 days) and lots of links/howtos were posted. Seek and ye shall find....
Don't go hydrolic unless you have to. Cable is IMO the best for a daily driver OR a race car. I'm using the modern drive line cable kit and cross member at the moment. The cross member worked GREAT but I'm not so sure about the cable kit. I had to modify the pedal bracket they sent me and I still can't seem to get the clutch adjustment perfect. Ron Morris sells a cable conversion kit and he just came out with a "better one". I havn't seen any info on his new one anywhere tho.
As for the drive shaft, when I swaped the C4 out of my 67 for a T5 I needed a new drive shaft because the way the stock one was made it wasn't worth modifying. I would recomend geting a brand new drive shaft made. Wenco built my aluminum drive shaft for under 200 bux including yoke and universal joints. Price on parts/materials has gone up so I'm sure milage may vary on that one.
My best advice on this one is that if you keep your eyes open and your are patient then you will find what you are looking for and you wont end up spending a ton of extra cash. Go slow and look for good deals on ebay or talk to people in your local Mustang club. You'd be suprised at how much stuff people have lying around they don't need or want. You can get stuff for really cheap, some times even for free.
I went with T5z and Lman is right, you can search and find a TON of threads on this site for a T5 swap. Going the TKO route is fine if you don't mind cutting up your trans tunnel (beware, there are many here who believe no cutting is required, but seem to be more that believe it is necessary. Heated discussions likely to follow). Here's a quick but complete parts list of everything I bought for my swap (real prices and found Summit to have the best price on the T5):
<TABLE style="WIDTH: 222pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=295 border=0 x:str><COLGROUP><COL style="WIDTH: 139pt; mso-width-source: userset; mso-width-alt: 6765" width=185><COL style="WIDTH: 83pt; mso-width-source: userset; mso-width-alt: 4022" width=110><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 139pt; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=185 height=17>Parts List</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 83pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=110></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>T5 Transmission</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="1140"> $ 1,140.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Bellhousing</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="40"> $ 40.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Blocking plate</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="20"> $ 20.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift fork</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="15"> $ 15.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift fork ball stud</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="15"> $ 15.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Flywheel</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="90"> $ 90.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Clutch/press plate</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="160"> $ 160.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Thrust bearing</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="10"> $ 10.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Trans/BH hardware kit</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="12"> $ 12.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Trans cross member</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="129"> $ 129.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Trans mount</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="36"> $ 36.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Slip yoke</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="95"> $ 95.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Fork Dust boot</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="34"> $ 34.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift handle</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="139"> $ 139.00 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift knob</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="39"> $ 39.00 </TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent" height=18>Hydraulic Clutch system</TD><TD class=xl27 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: windowtext 2pt double; BACKGROUND-COLOR: transparent" x:num="385"> $ 385.00 </TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 13.5pt; BACKGROUND-COLOR: transparent" height=18></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="2359" x:fmla="=SUM(B2:B17)"> $ 2,359.00 </TD></TR></TBODY></TABLE>
Lastly, I decided to go hydraulic on the clutch after researching potential interferance problems with headers and power steering. Do your own research before putting down the cash. If you are like me, it's worht spending the extra couple hundred bucks to know everything fits and works properly and will not have to be redone a couple thousand miles down the road. Click the link in my sig to review some pics on my swap. Good luck.
where did you find a bellhousing for 40 bucks? the cheapest ive found is like 150.
whats a blocking plate?
i see places like mustangs plus has conversion kits. does this come with everything im going to need excluding bellhousing, tranny, shifter, clutch, flywheel?
The Corral classifieds is a good place for used stuff. Plenty of bellhousings there, flywheels, etc
You have two commodities here, money and time. You have to decide how much of one you are willing to trade for the other.
I got a used bellhousing off eBay for $40 and spent another $30 to have the machine shop glass bead it. Take a look at my pics and you will be hard pressed to tell it from new. The blocking plate fits between the rear of the engine block and the bellhousing (view the pics and you will see it). You can find them on eBay as well for a lot less money than new. I found mine at a local service garage and I offered him $20 and it was a done deal. You can go with the complete kits from places like Mustang's Plus or Modern Driveline, but I found that the kits may not have the right combo of parts that I was looking for. This is a judgement call. I have the parts list by vendor that I will post in another reply since it's complaining I have reached the character limit. Hope this helps.
<TABLE style="WIDTH: 430pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=572 border=0 x:str><COLGROUP><COL style="WIDTH: 114pt; mso-width-source: userset; mso-width-alt: 5558" width=152><COL style="WIDTH: 68pt; mso-width-source: userset; mso-width-alt: 3328" width=91><COL style="WIDTH: 46pt; mso-width-source: userset; mso-width-alt: 2230" width=61><COL style="WIDTH: 54pt; mso-width-source: userset; mso-width-alt: 2633" width=72><COL style="WIDTH: 59pt; mso-width-source: userset; mso-width-alt: 2852" width=78><COL style="WIDTH: 41pt; mso-width-source: userset; mso-width-alt: 1974" width=54><COL style="WIDTH: 48pt" width=64><TBODY><TR style="HEIGHT: 38.25pt" height=51><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 114pt; BORDER-BOTTOM: #e0dfe3; HEIGHT: 38.25pt; BACKGROUND-COLOR: transparent" width=152 height=51></TD><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 68pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=91>Mustang Depot of Las Vegas</TD><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 46pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=61>Modern Driveline</TD><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 54pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=72>Summit</TD><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 59pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=78>Mustang's +</TD><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 41pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=54>eBay</TD><TD class=xl24 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; WIDTH: 48pt; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" width=64>Mustang Depot (eBay)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>T5 Transmission</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="1139.88"> $1,139.88 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Bellhousing</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="39.99"> $39.99 </TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Block plate</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent" x:num="20"> $20.00 </TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift fork</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="15"> $15.00 </TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift fork ball stud</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="15"> $ 15.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Flywheel</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="89.99"> $ 89.99 </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Flywheel bolt kit</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Clutch/press plate</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="160.88"> $ 160.88 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Thrust bearing</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="9.39"> $ 9.39 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Trans/BH hardware kit</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="12"> $ 12.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>BH/Engine hardware kit</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Trans cross member</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="129"> $ 129.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Trans mount</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="35.95"> $ 35.95 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Slip yoke</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="94.95"> $ 94.95 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Fork Dust boot</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="34"> $ 34.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift handle</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="139"> $139.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Shift knob</TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="39"> $ 39.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>Hydraulic Clutch system</TD><TD class=xl26 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: #ccffcc" x:num="385"> $ 385.00 </TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD class=xl25 style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD><TD style="BORDER-RIGHT: #e0dfe3; BORDER-TOP: #e0dfe3; BORDER-LEFT: #e0dfe3; BORDER-BOTTOM: #e0dfe3; BACKGROUND-COLOR: transparent"></TD></TR></TBODY></TABLE>
