Ign Switch wiring connections
1966ponyguy
33
Kentucky
I am finishing the new wiring and have ran into a question. Looking at the picture, the spade post in the 6 oclock position, should connect to the battery as incoming power. The threaded connection in the center is key controlled power out, the spade connection at about 2 oclock engages the starter sol through the s connection on the sol. The spade terminal at about 11:30 position is the coil / run position. The last spade connection on the outside of the connector that is in the 5 oclock position I can not find on any diagrams. Help .......... Am I correct on the other positions, what does the last spade terminal connect to, and roughly how many amps should a replacement ign switch be able to carry?
Once again, thanks in advance
I think you are correct
I checked the service manual, and I come up with the same pattern you did. Unfortunately my ignition switch is buried behind the A/C ducting. So I couldn't confirm it visually.
(IIRC) The spade at the 5:00 position is a ground spade, not used. You should double check that though. If you have a meter, and I am correct the spade will have zero resistance with the body of the switch.
If you have a meter you can ring out the rest of the spades too. That way you can't go wrong.
If nothing else, at least this will get you a bump back up.
Good luck,
Scott
Rated Amps for Ign switch
Does anyone out there know how many amps is safe to run through the switch? I have added relays to my H4 headlights and horn, can everything else run through the key switch. I have a new fuse block that uses the blade type fuses but only has one power feed. Since I have reduced the pull of the largest power drawers (no electric fan, and the fuel pump is controlled by a relay from the efi harness), will the switch power the fuse block safely. The block is rated for 100 amps, and has seperate ground connections that i plan on using for some of the circuits. I can't find anywhere that gives a clue about the ign switch power rating?
The ground connection makes since, I will test it out.
I've got to agree with Truck on that one
Looks like the original system would load to about 30A with coil, wipers, heater, radio, etc. Not sure I dig that though. I'd like to limit it to 20A or less. Funny I've never looked at it from this point before. makes me want to put a relay on the stupid thing now :rolleyes:
Of course, it's been working for over 40 years, so I guess that old switch must be pretty well built. Wonder if the replacements are that good?
