ignition box help
  • Thread starter Thread starter dyb003
  • Start date Start date May 14, 2006
D
dyb003
68
  • May 14, 2006
I have an older ignition set up in my V8 ranger. Engine is a 1990 5.0 HO but the dist and box are out of an late 70's early 80's van. I am thinking of relpacing the stock ignition box with an better/hotter spark box. My question is, how hard is it to go to a MSD box? and do I still run the resistor between the coil and the dist? Thanks for the help.
D
dyb003
68
  • May 15, 2006
any ideas? I need help on this. Thank you
wild86stang
115
Milan, OH
May 15, 2006
  • May 15, 2006
MSD's and similar ignitions are a pretty straight forward install in a Mustang 5.0, so it shouldn't be any different for you. They even sell a harness which I think eliminates the need to splice wires. I'm not really sure what you mean about the resistor, I'll leave that question to one of the electrical guys. If nobody responds, p.m. jhricker (spelling?) or hissin they both know everything electrical.
3 eyed snake
24
louisville,ky
May 15, 2006
  • May 15, 2006
MSD harness for 5.0 is about $18.00 I think. The directions are pretty straight forward, I'm no wiz, but with the harness its just plug and play really. No more than a hour or so.
D
dyb003
68
  • May 15, 2006
I was told that sense this is an older ignition set up that I had to run a resistor wire or resistor between the coil and the distributor or I would burn out the electronics in the distributor. It is an electronic ignition out of an older ford van, late 70's early 80's. So do I not need this resistor???
Engine Duraspark ignition box
  • limp
  • Oct 26, 2024
Fox 5.0 Mustang Tech Jul 21, 2025
manicmechanic007
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • dan50
  • Jul 18, 2026
dan50
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
C
Ignition Timing
  • churdle
  • Feb 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2025
Willybill32
