Ignition boxes, are they needed?
  • Thread starter Thread starter DemonGT
  • Start date Start date Sep 14, 2023
DemonGT
871
51
49
Sparta,WI
Sep 14, 2023
  • Sep 14, 2023
When is a ignition box needed? Do you really need one at all?
Thoughts...
Essn95
5 Year Member
Jun 21, 2017
817
622
113
Sep 14, 2023
  • Sep 14, 2023
I am running an unopened 95 Cobra with a Vortech v3 @14lbs of boost at redline. NGK TR6IX plugs at 0.034 and at first the car was good all the way to redline with just an MSD blaster coil. Coil failed shortly, car broke up at 4500 with stock coil. Went to screamin demon coil and the car pulled to redline without spark blowout for a few days and then above 5300 it was back. Finally installed a MSD 6AL and absolutely no spark blowout. I know people knock them, but so far mine has solved my issue. Reliability will be the next question.
rednotch
I'd like to remain having one chocolate starfish
1,441
665
143
south jersey
Sep 14, 2023
  • Sep 14, 2023
Do most need one, nope. The stock tfi systems pretty damn capable for most combos. I wouldn't bother with one on any "real street car" still running on your typical 91-93 octane pump gas. Now a track toy or something built to rev it can be beneficial but a typical basic ignition box on a mild build is absolutely pointless if it doesn't have a timing control or a rev limiter. Spark wise its not going to make more power.
Reactions: General karthief
Admin Dude
Jan 4, 1985
43,387
21,589
234
Box behind Walmart
Sep 14, 2023
  • Sep 14, 2023
Stock Fox Ignition System = Good!
Stock Fox Electrical System = Teh Suxxorz
My setup includes a Kenne Bell. Everything in the ignition system is stock except for my Boost-A-Spark. What it does is keep the coil saturated and regulated at an adjustable setting up to around 19V and is wired directly to the battery. Other electrical system demands don't affect coil saturation... This stays constant at your preset.
Reactions: mikestang63 and General karthief
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
D
Transceiver Ring
  • dtarang
  • Aug 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 22, 2026
dtarang
D
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
