Ignition Coil Wire
tmartintk
50
Hi everyone.. I just bought a 1989 mustang lx 5.0, it is a project car and a lot of the wire under the hood have been butchered so I have no clue which ones go to the coil....what color are the wires or is there any way that I could straight wire the coil to the ignition? Thanks for any help
The wires that connect to the coil should be connected via a wiring connector that contains the two wires. One is red wire with a green stripe, the other is a green wire with a yellow stripe. This picture shows the connector at the very top. Disregard the rest
Here's some links that you can use for wiring and vacuum diagrams
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
I can clearly see the correct wires that should lead to the ignition coil. Both have butt connectors on them, someone did a hack job installing an aftermarket ignition at one point. :nono: Pretty much the only reason to ever cut into those wires, although you don't really need to cut them to do so, but... :suicide:
